I am trying to get a new brushless motor driver
http://www.kelinginc.com/CNCmillingcontroller.html working with Mach3 speed control via my KFLOP and was hoping to get some clarification before I went and broke something.
Looking at the manual, page 10
http://www.cnczone.com/forums/attachment.php?attachmentid=111182&d=1279486851
it shows the external user interface port for PWM control. Specifically (in case the manual won't load for you) it has:
Pin 4, Start/Stop in the shutdown state to a negative pulse start, turned down in a negative pulse stopped, a negative pulse every time a status change.
Pin 5, Forward/Reverse: Positive/negative inversion pulse every time a status change
Pin 6: PWM control input, 500-5Khz of the PWM control signal, 10%-90% of the minimum speed can be controlled to the highest (Recommended frequency: 1Khz)
Starting with Pin 6, I read this to mean I should set a 1Khz frequency period and then vary the duty cycle from 10% to 90% to control speed. I have seen previous posts describing how to set PWM pre_scale and duty cycle. However I am unclear exactly what I should set in Mach3 in order to enable the speed control and send the proper notify to the control program. Do I need to configure Relay Control output pins in the spindle settings tab? How about the motor control PWM base frequency? It seems like this should all be controlled by the KFLOP and irrelevant to a notify message.
I've seen a post with a sample SpindleMach3PWM.c program:
//Plugin Notifications and defines..
enum { EX_DDA , EX_VMS, EX_COMMAND, EX_SPINON, EX_SPINOFF, EX_SPINSPEED, EX_MOTORTUNED
, EX_SETUP, EX_FEEDHOLD, EX_RUN, EX_ESTOP , EX_CONFIG };
int message = persist.UserData[0]; // Mach3 message ID
int Direction = persist.UserData[1]; // Mach3 Spindle Direction
float speed = *(float *)&persist.UserData[2]; // value stored is actually a float
printf("Mach3 Notify Message=%d, Direction=%2d, Spindle Set to %f\n",message,Direction,speed);
switch (message)
case EX_SPINSPEED:
printf("Spindle Speed Set to %f\n",speed);
SetBitDirection(26,1); // define bit as an output
FPGA(IO_PWMS_PRESCALE) = 65; // divide clock by 65 (1 KHz)
FPGA(IO_PWMS) = (unsigned char)(255.0f*speed); // set period
FPGA(IO_PWMS+1) = 1; // Enable
break;
case EX_SPINON:
if (Direction==0)
printf("Spindle CW ON\n");
SetBit(144);
ClearBit(145);
else if (Direction==1)
printf("Spindle CCW ON\n");
ClearBit(144);
SetBit(145);
break;
case EX_SPINOFF:
printf("Spindle Stop\n");
FPGA(IO_PWMS) = 0; // turn off PWM
ClearBit(144);
ClearBit(145);
break;
Which seems to indicate the Mach3 notify will provide me with a "SpindleSpeed" event followed by either "SpindleOn" event specifying direction, or a "SprindleOff" event. When is the SpindleSpeed event sent? Does it always occur immediately prior to a SpindleOn event or is it only when Mach3 senses a change in the spindle speed (from clicking on the GUI or a GCode block)? What I am concerned about is knowing how much error control to worry about in regards to initialization.
Finally this leaves controlling direction and start/stop. I understand WHERE in the c switch I should process these events but I'm afraid that my ignorance of PWM, and TTL combined with the possibility that the manual is not a particularly high-quality english translation means that I am not certain how to interpret what signals I should be sending to the driver's pins 4 and 5 nor, once that is established, how to produce such signals via the KFLOP.
On Pin 5, is "Positive/negative inversion pulse" a particular kind of TTL or PWM signal or does that mean I should pulse (turn on/off quickly) a positive voltage to go forwards and a negative voltage to go in reverse? Or something else entirely?
On Pin 6 I am at a complete loss, other than to be left wondering exactly how one generates a negative pulse via the KFLOP at all.
